Helping my buddy with a busted front axle
TerryMason
Administrator
Staff member
One of the guys I wheel with is in a bit of a spot, and I'm heading up next weekend to help him wrench on his Jeep. It looks like the Dana 30 font axle on his 2016 JK was full of mud, and the gears / front tires locked up. He was driving home when it happened and said it was terrifying. He had it with a shop for a couple of months, and they said everything was destroyed in the axle, but they ended up not getting the parts needed, or doing any repairs, so he brought it home. We're hoping to open up the axle, and at least access the damage - see if he needs a new ring gear, pinion, carrier, maybe even axle shafts.
The problem that we're having is finding a set of 3.21 gears, to match what is in the back. I can't find 3.21 ring and pinion, or carriers anywhere other than ebay (used gears). Ideally, we'd just buy an entire new front axle with gears in it, since neither of us have experience installing gears.
What do you guys think? Any tips or recommendations? Should we take a stab at installing our own gears, maybe even upgrade the front and back to something larger?
Here's another, maybe easier question:
Assuming there's a broken tooth on the ring gear or pinion, would it be safe to remove the ring gear from the carrier, and reinstall the carrier. Essentially making his Jeep two wheel drive? That way he could drive it again until we get parts.
I think if you can get the wheel hub side to stay, you should be good. For some reason, i think i remember people aaying there is some clip in the axle housing that holds something together so the wheel assembly doesnt get messed up. Maybe thats on yj and cjs, though?
I went over the weekend and helped my buddy swap his front axle out. Took us from 9:00 a.m. until 7:30 at night, but we got it done. We still need to do the rear axle but I think that's for another weekend
We ended up swapping in new axles instead of trying to rebuilding the old one. Because the new axles are different gear ratios we'll need to do both front and rear (old are 3.21 and new are 3.73). He got a heck of a deal though. Front and rear JK axles with 3.73 gears for $1,000. They were a little rusty because they've been outside for 2 years but they seem to function great.
The shop was accurate when it said "the front axle is just full of mud". Here are some pics of the axle we pulled out.
Sent from my Pixel 7 using Tapatalk
