Do I have a bad torque converter?
TerryMason
Administrator
Staff member
2005 Jeep Wrangler 4.0L with a 42RLE transmission.
Symptoms:
  • Loud whine when on the gas. Really easy to hear at 40mph and above, and if I let off the gas to coast the sound goes away. The sound stops for a moment as the jeep downshifts, and it almost sounds like it grinds / growls to a stop.
  • Infrequent shudder when going down the road. Only once in a while, but I'll be on the highway, and will feel a very brief series of bumps, like I've gone across a rumble strip.
  • Some black on the trans dipstick. The fluid is less than 5k miles, and there is a bit of black to go with the pink of the fluid.
I thought this was the torque converter for sure, but I just called my local transmission shop, and they said that I have a different problem. He said that if the torque convert was bad then I wouldn't be able to drive. He also said that the torque converter would not contaminate the fluid.
What do you guys think?
No idea but i had to buy a replacement for my 42rle. It lost reverse
I asked Chat GPT, and it told me that this is likely a bad torque converter.
Not sure if this is just AI telling me what it thinks I want to hear, or if this is legit, but it sounds good:
Your symptoms—whine under acceleration (especially at higher speeds) that vanishes when coasting, occasional shudder like hitting rumble strips, and black residue on the dipstick despite fresh fluid—point strongly to a failing torque converter, particularly the clutch or internal bearings wearing out. This is a common issue on the 42RLE transmission in Wranglers, often tied to heat buildup, partial lockup problems, or debris from clutch material circulating and causing contamination. The whine could be from worn needle bearings in the converter creating a whirring noise that changes with load, the shudder from the torque converter clutch slipping or engaging erratically, and the black stuff is likely clutch friction material or fine metal particles breaking down, which can show up even with low-mileage fluid if there's internal wear.
The shop's advice doesn't hold up based on typical 42RLE failures. A bad torque converter doesn't always make the vehicle undrivable—many people limp along with partial failures for thousands of miles before it gets worse, though it risks damaging the rest of the transmission over time by sending debris through the system. And yes, torque converter issues absolutely can contaminate the fluid; that's a classic sign, as worn clutches shed material, and damaged bearings or seals let particles mix in.
That said, don't jump straight to replacing the torque converter without confirming. Other possibilities like a failing transmission pump (which can whine under load from low pressure or wear), clogged filter, low fluid level, or even valve body issues could mimic this, though the combo of symptoms leans heavily toward the converter. The 42RLE is notorious for these problems in Jeeps, especially with stock setups pushing larger tires or in hot conditions.
Here's what I'd recommend stepping through before deciding on a replacement:
  1. Check fluid level and condition properly: Make sure the engine is running, transmission in neutral or park, and fully warmed up (drive it for 10-15 minutes). The dipstick should show full— even a slight low can cause whine and shudder. If it's low, top it off with ATF+4 only. But with black residue already, drain and replace the fluid and filter anyway (about 4-5 quarts for a pan drop). Inspect the pan magnet for excessive metal shavings; a little is normal, but chunks or a lot points to bigger internal damage.
  2. Scan for codes: Hook up an OBD-II scanner (or have a shop do it) to check for transmission-related trouble codes like P0740 (torque converter clutch circuit) or pressure solenoid issues. The 2005-2006 TJs sometimes have PCM (engine computer) glitches affecting the trans controller, which could contribute.
  3. Test drive and additives: If no codes, try a shudder-fix additive like Lubegard Instant Shudder Fixx or Dr. Tranny's (follow the bottle instructions, usually just pour in). Some folks report it quiets minor TC clutch issues temporarily. Pay attention to when the whine/grind happens— if it's tied to lockup speeds (around 40-50 mph), that's another TC clue.
  4. Get a second opinion: Take it to another reputable trans shop for a road test and pressure test. They can hook up gauges to check line pressure (should be 60-100 psi idle, higher under load) and see if the pump is weak or if there's a converter-specific fault. Avoid chain shops if possible; find one familiar with Jeeps.
If diagnostics confirm the torque converter, yes, replace it— but do it as part of a partial rebuild if there's debris, to flush the cooler and replace the solenoid pack or valve body if needed. A remanufactured TC runs $200-400, plus labor (total job often $1,000-2,000), but ignoring it could lead to a full trans failure down the line. If the trans is high-mileage or you've got mods like bigger tires, consider upgrading to a beefier aftermarket converter with better internals to prevent recurrence.
In short, the shop sounds off-base, and your initial hunch is likely right, but verify first to avoid unnecessary work. If you can share mileage, any mods, or if there are codes, that'd help narrow it further.
Careful trusting AI on web information. There is so much poor information the mass of like information is reported.
It’s like finding a good mechanic. They will be straight with you and not try to soak you.
What fluid did you use??
https://www.jkowners.com/threads/42rle-blown-after-trans-service.377690/
I'm with you on this. I don't trust AI in general, however I do think it's good as "yet another opinion".
I've been using Valvoline ATF+4 for some time now. Since I bought that fluid extractor I've changed the trans fluid (well, half at a time) every other oil change.
My Jeep still runs great. I could hop in it now and go for a spin - I just have that loud whine, and the occasional stutter (like driving over rumble strips). My thought is that the torque converter is on the way out, and if not treated will die and take out my Transmission. I've stopped driving it until I figure things out.
I bought a re-manufactured torque converter from Summit Racing for $130
I'm going to buy a transmission jack, and take a stab at replacing it myself. It looks easy in theory, but I suspect that everything weighs a ton and will be hard to work with. This is my first stab at any transmission work.
I'd appreciate any insight. My thought is that as long as I don't drop the transmission, I'm only out $200 or so if the torque converter doesn't help.
It is heavy, the trans andnthe torque converter. When you reinstall the torque converter, make sure to read up on whether it has to "seat" a click or three.
My son and i pulled his auto trans in his bmw and his torque converter had to click twice so it was seated on the pump spines properly. We didn't fully seat it and it destroyed the pump, which cost more then the trans to replace because of the labor.
That stinks man. I'm going to pay extra attention to this.
Here is a good explanation
Hold speed and watch rpm. If rpms jump the converter is failing.
I've watched that video, and it's really good. Surprisingly few videos on this topic.
I have the whine (which has gotten very loud), and the shutter. I haven't noticed any slippage yet - either I'm catching it early, or misdiagnosing.
I started taking things apart today. I did notice right off the bat that there appears to be a leak where my transfer case selector mounts
I also noticed the transmission mount is ready to be replaced
I bought a new transmission Jack, but I'm not exactly sure how to best position it. My plan is to separate the transfer case from the transmission. Assuming I'm removing just the transmission, should I put my Jack under the pan or would that end up crushing the pan? There doesn't look like much space to put it anywhere else.
Sent from my Pixel 7 using Tapatalk
No, put it under the pan.
Also, support the engine in case it tries to tilt and pull any wires or put the fan into the radiator
Consider the low profile trans mount to help offset drivetrain angles with the lift.
Got some more progress last night. The transfer case is out. It wasn't very hard at all, although it was heavier than I expected.
This video is a good one to walk through how to remove the transfer case
He did have alot more fluid pour out his transfer case than I did. I ended up with about a 4 inch diameter puddle.
Consider the low profile trans mount to help offset drive-train angles with the lift.
I was looking into this just now, and I see the same guys that made my skid plates make a low profile mount
They do say that this mount will cause more vibrations - I'm betting that it's due to the smaller amount of rubber used.
I've got a engine mount lift along with a one inch body lift. In my mind I've lifted the engine and straightened out the driveline angles some - I'm not sure if this is reality or not.
We are in the process of dropping our 42rle also. Finally, ha ha ha. I am letting my son do all of it and only help if its a clip or some dumb part, or when its a 2 man job. He is si anxious to be done, he took it around the neighborhood one last time before we started and said he cant wait till be able to do the same speed as everyone else on the highway again.
The ol 2.5/5 speed in the 97 doesnt like the highway with the 31s on it.
That's awesome. I'm really taking my time on this - I'll probably drop the trans later this week. I plan on pressure washing everything including the bottom of the Jeep before I put things back together.
I'm debating on if I should open up the transfer case or not. I don't have any reason to think there's a problem, but it's on my bench right now, so this would be the time.
Oh yeah, the top two bolts on the trans are t11 torx
