'03 TJ Heater/AC Fan Switch/resistor
PlasticNerd
So, my Heater/AC fan only works on high, not the other three speeds. From what Ive read and heard I need a resistor, not a new switch, If the three low speeds worked it would be the other way around. Any thoughts for me? :-| Thanks.
Actually most say try the resistor first because it is the cheapest. The heater/ A/C fan switch is most likely your problem. It is a known problem, that Jeep fixed in 06. Try the resistor, and hope it is it. Lost low and mid high...it was the switch.
