Baseline 4x4
Own a 2007-10 Wrangler? You love its versatility, but find yourself wishing it had a little more more performance? Rugged Ridge has designed a series of bolt-on performance additions with you in mind. Our custom Exhaust Headers are engineered to deliver improved performance. The 3.8L isn’t a bad motor it just needs more air to “breathe†properly. To awaken your motor simply replace your restrictive stock exhaust manifolds with the free flowing Rugged Ridge design. Our headers increase exhaust gas exit velocity to move more air through the cylinder head’s combustion chamber resulting in performance gains. They are constructed of 409 stainless steel to ensure a long operating life. Each complete kit includes manifolds, gaskets, hardware, clamps and easy to read instruction sheets. For optimum performance use in conjunction with Rugged Ridge’s Catback Exhaust and Air Intake System
17650.53 - Rugged Ridge Exhaust Header, Stainless Steel, 07-10 Jeep JK Wrangler with 3.8L
Rugged Ridge has built the most rugged exhaust system available for your Jeep®! Our cat-back systems feature Vortex mufflers, stainless steel hardware, and mandrel bent aluminized pipes. Our mufflers are constructed from heavy-duty 14-gauge aluminized steel, are seam welded, and feature reinforced inlets and outlets. Not only will you gain performance and a deep throaty sound, you’ll have the toughest exhaust system money can buy.
17606.55 - RUGGED RIDGE CAT BACK EXHAUST KIT VORTEX PRO JEEP JK WRANGLER 07-10
Open up your Jeep's exhaust with this great looking and long lasting stainless steel exhaust system. You'll get a mellow exhaust note that will set your rig apart. The 2-1/4" mandrel bent pipes give hot exhaust gases a smooth exit without constrictions found in crush-bent pipes. This is a bolt-on system that installs after the catalytic convertor to keep you emissions legal. The dual split exits feature slash cut and rounded oval tips for a tough look. Includes all necessary mounting hardware.
17606.75 - Rugged Ridge Stainless Steel Cat Back Exhaust System With Dual Tips, 07-10 Jeep JK Wrangler
Want more horsepower, better throttle response, and improved acceleration? A Rugged Ridge Air Intake System can boost your performance, while helping you keep extra cash in your wallet. Our polished aluminum mandrel bent intake tube replaces the restrictive factory air box to help improve fuel economy and performance. A black powder coated heat shield separates the fi lter from engine heat, dirt and debris, as cold air is drawn through a high-fl ow conical air fi lter. Unlike other reusable air filters, our dry panel design never needs oiling, which keeps your MAF from being damaged by excess oil! The simple bolt on installation gives you power you can feel, adding up to 10HP and 12ft lbs or torque, depending on application.
• Polished mandrel bent 6063 aluminum air intake tube.
• Simple no-drill installation bolts on using simple hand tools.
• Intakes kit includes black powder coated heat shield.
• Improves fuel economy
• Adds HP and torque.
• Includes a high-flow conical dry panel fi lter that never needs oiling.
17750.06 - Rugged Ridge Air Intake System, 07-10 JK Wrangler 3.8L V8
Free Shipping on all orders over $199!
Tony Feichter
Jeep Parts and Accessories
Baseline 4x4 Outfitters
1-866-554-5946 Toll Free!
260-636-7565
www.baseline4x4.com Jeep Parts and Accessories
TonyFeichter@baseline4x4.com
Tony Feichter
260-636-7565
