2.4 steering upgrade
Bigcountry10
I had to change my steering box, so I switched to the PSC w/ram assist. This kit involved changing the high pressure line. The new hose did not come with the pressure sensor and the old one was thrown away for some reason. Now I have the check engine light on caused by this not being connected. Is there a way to trick the computer into thinking it's there. Without it the engine does not know that it needs to idle up when turning the wheel at mall crawl speed causing the engine to die.
I believe that you can get this at advanced auto parts, or your local parts store.
Niehoff Ignition Power Steering Pressure Switch
Part Number: OP26763
Take a look at this part before you buy it though - I just grabbed this info off of google - I haven't tested it myself.
