The 4.0L TB will not improve throttle response but you will get a little more power and better mileage if you can keep your foot out of it. You won't see improved throttle response unless you remove the taper from beneath the throttle plate in either throttle body. Look down inside your throttle body and slowly open the throttle and you will see just how much throttle movement is needed for the throttle plate to clear the taper and allow air to pass.
I manufacture 62mm throttle bodies with a straight bore, the throttle response is lightning fast on the 2.5L and 4.0L engines.
Most throttle body spacers are large enough for a 4.0L throttle body, so don't ditch it unless you're sure it's a bottleneck under the throttle body. I think the helix bore spacers are a scam, I make mine a smooth 62mm straight through. The air is moving too fast for a helix to do any good.
