Intense-Dakota
2004 WJ w/ 4.0L and 4x4. I have replaced, plugs, IAC, TPS, Crank Position Sensor, removed and completely cleaned throttle body (with sensors out). I have done an oil change, checked motor mounts and trans mount (they seem to be ok).
It runs rough (not to the violently shaking, but rough enough to get a massage while sitting still) in Park, Neutral and all drive gears while sitting still (except for the first few second when I start up cold when the idle is still around 800-900 and then it drops to normal (around 550 rpm's). I just recently had it almost stall a few times when stopping at a light (RPM's did not seem to drop when it started to stumble). It will idle rough almost like rotational type of shimmy (hard to explain, but it will run rought for a second, then smooth for a second, then rough for a second and so on). It does not seem to be effected when the rpm's are any higher then idle. The tac always stays steady and does not fluctuate with the idle at all. Reseting the computer after changing IAC fixed the stalling for about 3 days. I reset the computer today when changing the CKP Sensor, and its not stalling, but the idle still seems to rough. The only things I have not checked or changed yet are the following:
Upstream O2 sensors
Downstream O2 sensors
Map sensor
Coolant temp sensor
IAT sensor
Fuel Filter/Regulator
Injectors
Coil Pack
Computer
I would rather not keep replacing parts with no change (except resetting the computer. I do have a warranty on it, but I have a $100 deductible so I am currently just replacing all the parts that would run less then $100. I have already had it in the shop 2 times, and they say (the famous I realy should'nt be a mechanic saying of) "We ran the diagnostics through the computer and it said everything was fine", so I really don't want to take it back again. I do have a vacum gauge, but not sure if that would help diagnose it or not (I use it to tune my dart, never on a fuel injected vehicle).
BTW- There is no check engine light, and I have pulled the codes 3 times with nothing showing (using the key trick 2 times, and AutoZone pulled once).
If anyone has any insight into this at all, even if one of the "havent changed parts" fixed your idle issue , please, please, please, please let me know.
Upstream O2 sensors
Map sensor
Coolant temp sensor
IAT sensor
Injectors
Coil Pack
Computer
