I'm looking for info or links to info. I've got an '84 CJ7 with the 258 six.
I'm going to pickup a vacum gauge to do some diagnostics. I'm getting a lot of oil through my breather tube into my air filter housing. So what I'm getting at is I need to decide if I'm getting a lot of blow-by or maybe my cam is so worn that my manifold vacum is low. Seems like these two possibilities would have similar consequences. My jeep lacks the power that I think it should have, but then I don't have a good reference point since it was in worse shape when I bought it. I checked the compression and that seemed fine ~150 in all cylinders. I also put in a PCV valve from a big V-8(I was thinking more flow), that helped, but I had to tune the carb a little.
My instincts are leaning towards the cam. Does anyone have any thoughts on putting a new cam in an old engine? Also does anyone know much about interpretting vacum :?:
