88 jeep wrangler f/s philly/sj area 3000 OBO
its an 88 wrangler, black, 4.2 motor, auto trans.bout 180000 on it
the good
other than the windshield frame, very little rust
the carb has been swapped for a motorcraft 2100
nutter bypass has been done (disabling the junk ignition computer they put in them)
upgraded tfi ignition.
ford tarus 2 spd fan
new radiator and aux trans cooler
optima yellowtop deep cycle battery
4" rough country lift
31x10.5 tires, fronts are yokohama geolander a/t's, rear are cooper discovery m/ts i also have 2 more coopers on ford bronco rims
comes with genuine hi-lift jack and assesories
bottom end of motor was rebuilt around 160000
older but decent shape black vinyl besttop supertop
vdp sound wedges in back
hurculined floor pans
new drivers side floor pan
both hard full doors and vinyl superdoors(they dont make theese anymore)
also comes with 1" shackle lift
1" motor mount rizers
extra windsheld frame with fresh paint
side mirrors for doors off driving
sony head unit
newer black vinyl front seats
carpet over the herculiner, for comfort
all of which had been done within the last 2 years
the bad
needs trans rebuilt
needs gas drained and replaced, was parked bout 9 months ago and ran than, fuel has gummed since than wont start
must be towed away, can do this for you
the windsheld frame is very rusted, and leaks, hence the new frame
small hole in top of gas tank, leaks if over 18 gallons full
the ugly
well its a 20 year old jeep, and could use a paint job, and has a few small dents and dings here and there
also up for trades, need a reliable d/d would prefer VW or older bmw
great project, just needs some tlc
