fishskuller
89 jeep cherokee L6 4.0l has been sputtering up hill on accelerating and failed inspection for carbon monoxide level.so i put it on a diagnostic tester and all the sensor's were going wacky.it was running from rich to lean. All the wires and plugs are good, so i turned the distributer a hair to try and adjust the timing and evrything started working correctly and it was running lean, all the sensor's were fine, then after a couple of day's it started to sputter a little at high speeds. Could this be a timing chain problem or is there a better way to get the timing set correctly? please help this has been going on for a while oh and the distributer is recently new,it's been replaced a couple of month's ago.
