89 XJ motor swap
Keanu Govan
I've been looking into some motor swaps and was curious to what are the most reasonable to install time other than the LS1 and small block 350's. I was also considering maybe a 4bt, cause i figured 6bt is too big and wouldn't fit? diesel is most fuel efficient and most torque output what do you guys recommend? wanted to get some opinions before i go all the way in with this project.
I do a lot of offroad krawling so i would have gone with the 4BT instead of the 4.7 stroker that i finally went with if i had found one at a reasonable price. Low end torque was what i was going for.
I did a 4 bt in a 99 xj. 6 months badazz! Loved it. But broke the xj's back. Scrapped project since I didn't want to spend $3000 at a welding shop for repair and reinforcement.
Ended up with 2 xjs here. 92 with 4.8 stroker, 89 with Mercedes diesel and, 90 mj with the 4 bt. The stroker is the best off roading here in Florida. The Mercedes is awesome dual purpose. The Comanche is a beast.
