'94 YJ won't start
I don't have any voltage going to the coil. I've checked all fuses and are all OK. I think I've checked all relays but don't know if i've found all of them. Need help please!!!
Check the ASD relay, maybe swap it with another relay and see if that helps. Then check all the fuses in the PDC under the hood, large and mini fuses.
If that checks out, I'd suspect the CPS (Crank Position Sensor) on the bellhousing.
had same problem with 89 2.4 changed coil still had no spark changed cps this seem to work.I think Bounty Hunter gave me this advice, my cps was on driver side bell housing good luck, Dave
Well I replaced the ASD relay and the CPS still nothing. All fuses are ok. I'm lost at this point. Help please!!!
