95 yj clutch cylinder replacement
djcrigh
Hi:
I took my 95 YJ to the local mechanico where I am staying in Mexico because the clutch was acting up. At the time I didn't know the master slave cylinders are a sealed system in the 95. Well to make a long story short he tried to bleed the system and more or less made things much worse. So he has ordered me a new master/slave/line unit and because I am now leary of his expertise I want to install the new system myself. I have been searching on line for how to instructions and everything seems pretty straight forward except for one thing. Some of the instructions say it is a completely sealed system including fluid, just bolt the master slave cylinders in place and go. Yet other instructions are telling me I have to fill the master cylinder with fluid. So can anyone clarify this point for me?
Thanks, Don
Lo de Marcos, Nayarit, Mx
If its anything like the 97 TJ's are then you have to add fluid and bleed it like a brake caliper....easy to do...I did it myself, in my driveway.
