95 yj partout
60mg
Below is a list of available parts:
hood - $90
tub - $230
master cylinder w/booster - $15
front seat belts - $35 each
rear seat belts - $25 each
spare tire - $40
brake master cylinder (with booster) - $30
clutch housing bell for 2.5L motor (outside mounted secondary clutch cylinder) with inspection cover- $30
front grill - $75
tank (15ga) - $70
dashboard beige plastic set (no top dashboards bezel) - $50
top dashboard bezel grey - $15
fuel sending unit - $15
crossmember - $85
cage CJ with safety belts and floor buckles - $40
cage YJ family style with padding (cage only) - $90
cage YJ family style with padding (with belts) - $140
Parking brake assembly - $20
accelerator pedal assembly - $15
4WD shifter - $25
Shifters boots - $15 for both
Front brake cylinders - $20 both
Heater - $120 whole setup (adjustable cable needs to be replaced)
I might have missed a few things here and there. Shoot me a pm and I'll check. Shipping applies to anything other than local pickup.
what color are the rear belts? i am looking for black
Update to OP:
The front passenger belt has some rip at the bottom so the price is $20 (use at your own risk) plus applicable shipping. Pm me if you want to see picture of it.
I need a front seatbelt, sice and color dont matter as long as it works ok. how much shipped to 11776?
hood - $90
tub - $230
spare tire - $40
front grill - $75
tank (15ga) - $70
crossmember - $85
4WD shifter - $25
Right side only. Driver side belt has a small rip almost by the lower mounting bracket. In case it works out for you -$45 delivered
two rear seat belts and shipping to 78418, please :)
