Hello
I have traded for a 99 tj with a 2.5 which was recently rebuilt. The problem is it starts bucking when under load around 2000 rpm. Researched this problem all over the web but there is no certain fix. I do have a snapon code and data reader but everything reads within range, and no codes.
These are sensors i have changed so far
Upper o2 sensor
Tps
Cps
New distributor, and pickup plate
New cap rotor plugs and wires
Still bucks and jerks.
I do know the checkvalve in the regulator leaks down from putting pressure tester on, but does hold 50 lbs ideling and revved up. Also have done a compression check and everything is within spec.
I am so frustrated and dont wont to spend more and more money changing parts without some sort of direction.
PLEASE HELP
Upper o2 sensor
Tps
Cps
PLEASE HELP
