My Jeep A/C stopped working I checked the Freon and was empty, I filled  it with A/C pro which has a sealer in it it is now full and holding  pressure but th Compressor clicks on and off every few seconds.I  replaced the high side cut out switch and the low side cycling pressure  switch and still have same problem. My Freon is reading 45lb then  pulsates down to 25-28 lbs. When I bypass the low side switch the clutch  engages and stays on. However the compressor gets hot as well as the  area near the high side cut out switch. the line leading to the H block  is cold. Any suggestions as to what to do next.
Thanks
			Thanks
