they didn't have abs? hmm, i never knew that.
you can but you will probably have to bend your own brake lines, unless the 00 and 01 came with it. then you could get it from one of those. if not, you need the computer, the master cylinder, the abs pump, the harness, the sensors, the tone rings, all of it.
