Again, thanks so much for your replies guy's.
I just got back from looking at the YJ. The guy's asking $1300, and it's a fair price for the shape it's in. I figure if I go with this one, I might be able to talk him down to a good few hundred.
The nice thing is, the guy did do the body work, all new steel.. no bondo anywhere. Even fixed the floors right up, not one hole in them. Actually, afew holes need to be drilled for afew mounts. He dropped in a bran new rad, the starter looks pretty new, he's got all new seals all round, barely any rust on the thing.
However, there are some issues with it. The grill is riddled with rust bubbles, looks like only surface though (been painted over). I plan to get the CJ style grill.. not fancy on the square lights. And the nice thing is the swap doesn't involve too much work.
All the mechanical seems to be good. Universals are still in surprisingly good shape.
Onto the other small issues: The frame has a small hole in it on the inner driver side right above the axle, easy to get at and fixed. There is one spot on the rear drive thats rusted and bent, right at the curve... still and easy fix. And lastly, the passenger side, the guy replaced the sheet metal... but kinda rushed it and warped all down the side. But thats a fairly easy fix.. nothing a good beatin cant fix.. right?lol
And the passenger door is missing the lock. Looked at it.. how the hell do you get that out.. and more importantly... how the hell do you get one back in those doors?
So, after reading that, what do yall think? Should I make an offer to the guy? Or should I hold out and try and find one with the MPFI?
