Auto Transmission Problem
romar
Have a 95 YJ, have had the transmission rebuilt twice, AAMCO said defective parts.Im leaking fluid from the transmission connection to the pressure line,about a quart a minute in gear. Replaced the fitting, still leaks, the line looks good. None of the lines are stopped up and new radiator was put in today. Should I replace the line, or can anything else be causing so much pressure? Any suggestions? Its not the Jeep I would have bought if I had known anything about Jeeps at the time. But its mine so I just keep on fixing it. Every Pocket Almost Empty[addsig]
1055898
Trade it for a 5 speed. Autos and Jeeps are just a bad match in my book. tug[addsig]
1055913
Unhook the line (I´m guessing cooler line) and take a real close look at the flare. Repeated tightening will eventually crack it. The crack often requires a magnifying glass to see. If you suspect your cooler lines are plugged, take of both and blow through there. After the oil comes out (not that much) you can get an idea if it´s restircted or not. Putting some compressed air through there, will often help dislodge crude, but keep the pressure below about 30 PSI or it can cause damamge.[addsig]
