carnuck
I have a '76 shortbox J10 I was going to build up, but I picked up an '82 Honcho I'm going to build instead.
Here's the scoop:
'76 J10 body with J20 axles (Dana 60 rear and Dana 44 front with RH drop) unsure of the gear ratio, but it felt very low when I test drove it a bit with the 360 it had before. (that motor/trans went to a different project a year ago) I would guess 3.73 or 4.10
Cab has some rust issues and the fenders are dented. Box has lots of rust scale (previous owner took it to bare metal and didn't paint it)
I have a complete '88 Chev stepside box I was going to put on (valued at @$800)
Motor and trans for this: I have a running 360 and T18A/NP208 (31 spline Ford setup) with LH drop (I was going to take the input spline from the Ford style case and put it in a Dodge NP208 I have)
It's coming from my '82 Honcho (I'm putting my 304 in with an AX-15 for daily driving)
I have an '83 J10 long box that some bits can be "borrowed" from, but the box is going onto my son's Jtruck in Canada.
Figuring $1,000 for the works
I also have 33/12.50/16.5s on alloy rims to go with it. (or for $1200 more I have a set of brand new 37" tires on rims)
Here's the scoop:
