AX15 Shifter
stumblnyj
Member
Greeting Jeepers, Has anyone encountered an issue with the gear shifter falling off the post (portion attached to the transmission)? This is the second time I've had the shifter come loose/ apart since I did a SBC swap in 2017. There is a two piece metal clip and a thin rubber sleeve that wrap around the post and the shifter slides over the top and clicks in to secure. The last time this happened I was driving down the road and the rubber sleeve didn't make it home lol. I was going to drill the shifter, tap it and secure to the post with a bolt. My only hesitation is how thin the metal is on the shifter. Have any of you had to deal with this issue? What was your fix? Thanks for at attention.
