H huntnducks New member Jul 6, 2008 #1 so if i go with a dana 30 with disc brakes , that should just be an unbolt bolt in from my dana 30 with drum brakes 76 cj5 6 cyl. 4 speed
Bounty__Hunter Super Moderator Aug 15, 2008 #3 Should be, if they're both narrow track axles. Don't know about widetracks.
J jps4jeep Super Moderator Aug 15, 2008 #4 NT and WT axles have the same spring perch and shock locations from 75-85
J jps4jeep Super Moderator Aug 15, 2008 #5 the only difference might be the pinion yoke. there were two different joints used on the front depending on the engine and year manufactured, might be a 1310 or 1330 joint. you can swap one from the other axle though so no biggy
