My 97TJ just recently developed a sporadic shimmy. I have 32's with a 2 inch terralift. Since the shimmy started I replaced the steering shaft(all the u-joints were shot), had it on a lift and all tie rod ends, knuckle, trac bar, and steering damper appear good according to the guy at the tire shop who would have sold me a repair job if he could have. The steering damper is only about 6 months old and when pulled loose at one end is still good. My tires still have about half the tread left, and show no signs of cupping or uneven wear.My shock bushings were shot but I replaced all my shock this evening. It drives straight with no pull and runs straight while braking. On the way from my shop to the house the shimmy/wobble showed up as bad as ever. As I said, it is sporadic. It seems to manifest itself at speeds above 45 or so, usually needs a small bump to set it off. Does often go off in a long sweeping left turn but never in a right turn. Sometimes starts while braking and braking never helps just makes it worse. the shimmy is very violent, jerking the steering wheel left and right. with the front end jumping around. I, all my buddies, the manager at Auto Zone(my cousin), and the guys at the tire shop are all stumped. If anyone can offer any advice it will be appreciated.
