Turbogus
Active member
Howdy from Oregon folks
Well, after getting a second battery mounted up with minimal space under the hood of these old CJ's I got me this here Stinger SGP32 isolator rated at 200 amps so if I ever upgrade my alternator I'm already set.
The trouble is, I'm trying to wrap my head around what the instructions mean by "Connect one samll terminal to true ignition power from your ignition harness. When tested, true ignition will keep power through the cranking cycle of your starter. Verify that your power source is true ignition"
From another forum one poster remarked that this'd be the power wire from the alternator, (that feeds the starter relay, if I'm correct)
Since I have more faith in the kindly folks here I thought I'd run this by y'all and see what your think, before I burn up any wiring. :sawzall:
Thanks, and a lift of the lynch lid for your response.
