F flip124 New member Dec 7, 2003 #1 Can someone please tell me where the belt tensioner is on a 4cyl engine. Just needs to be tightened a bit. Thanks TJ
T Tug-n-pull New member Dec 7, 2003 #2 Just loosen the bolts on your alternator and apply tention and retighten back in place. tug
J jeepin916 Active member Dec 7, 2003 #3 hey its not liek that on a TJ, tug the tensioner on the TJ 4cyl is behind the power steering pump on the bracket, its a long bolt that you can tighten and losen to adjust the tensioner pully
T Tug-n-pull New member Dec 8, 2003 #4 Sorry I keep forgeting how all new age and different the TJ's are. I guess I am behinde the times here, most likely will stay that way. sorry tug :?
