laredo2006
Hey there, I have a 2006 grand Cherokee 4.7 Laredo with 125k miles running smooth..
Can I get these services done anywhere or should I get them done at the stealership because they have better fluids?
1. Brake fluid flush w/Fluid from Dealer? Which one though? (MOPAR® Brake Fluid DOT 3, SAE J1703 (If DOT 3, SAE J1703 brake fluid is not available, then DOT 4 is acceptable. Use only recommended brake fluids.)12 oz. Bottle - p/n 04318080AB or 32 oz. Bottle - p/n 04318081AB?)
2. Power Steering Flush w/Fluid w/1 Quart Mopar® Hydraulic fluid/Power steering fluid p/n 5142893AA/ Fluid from Dealer?
Someone also mentioned I shouldn't bother doing a power steering fluid change unless there is a problem...?
