Gennybro
Active member
Have 94 yj 6cyl manual transmission. I replaced the front calipers and roters since the passenger side caliper went bad on me, I replaced both front brakes.
Replacing the calipers I just unhooked the brake line and sit it aside installed the componets, hooked the brake lines back up and and bled the front brakes.
Was unable to get pedal pressure, a little but not much. So I decided to bleed all the brakes starting with the rear passenger, next rear driver, next front passenger, then front driver side.
The best result as far as pedal pressure was after pumping them I could get half a brake pedal. But upon releasing the pressure and waiting about 20 seconds and stepping on the brake pedal it would go all the way to the floor. Able to pump them back up and same result. Then I pumped them back up with the engine off,got half a pedal, started the jeep pedal went to the floor upon starting.
Two people seem to think that the diaphram in the brake assist may have ruptured. But I thought it odd cause the brakes had pressure before I did this operation, so the diaphram was good at the point of time parking it and changing the calipers.
The proportion valve which set underneath the master cylinder has a rubber boot on the end of it. From doing a little research last night on this site I figured that may be the problem. So I pulled the rubber boot off expecting to see a pin or something to push or pull, But ahhh I pushed and pulled on the thing and nothing happened. So I is a little confused .
Thanks
Thanks
