Brake problems 06 Rubicon
JEEPFIRFGHTR
Bought new rubicon back in may and have had trouble with brakes. I have been to dealer and had rotors replaced .Brakes cause flat spots on rotors, anyone else had this problem?:???:
Never heard of "flat spots" before. Rotors will warp as a result of getting too hot and sometimes hot then wet. When they are warped, you get a lot of feedback in the pedal. The only soution then is to replace the rotor or have it turned down on a lathe. You could possibly find some vented (drilled) rotors.
