jkruegel
Im here in SOCAL and I bought a 92 YJ with the 4.0L injected motor with the 5 speed manual trans. I have now replaced the CAT, O2 sensor, fuel pressure reg, spark plugs, map sensor, coolant temp senor and thermostat. Ive checked the cylinder compression (150psi to 160psi). Ive used Seafoam in the engine and fuel. I can not get it to pass the 15mph or the 25mph NOx test. it will pass all the others. It has no EGR valve and I can not adjust the timing, Oh yeah, I opened the gap on the plugs to 0.045 instead of the 0.035 that is recommeded. Does anyone have any suggestions besides the C4 Im about to put under the engine.
