Cant stop the jeep....
laneiac
So, I did front and rear brakes on the Jeep a while back, and it wont stop. The brake pedal is extremely firm, and if you press harder stop it the brakes lock up. What gives? It is scary to drive, the brakes lock up so easily.
95 Wrangler
Have your calipers looked at, or you can bleed them to let some of the pressure out of them
Does one wheel lock up or a couple of them?
It could be the master cylinder. Is the vacuum line connected to the power booster? Make sure it's not leaking and that it had vacuum.
Seems to be the rear wheels, the cylinders are new. But I will proceed with rebleeding them and see if that helps.
Ill also check the vacuum to the booster...
