[FONT="]Maybe there's another gasket thats better than the blue Fel-pro paper gasket for the 4.2L, I don't know. The one that came off was metal reinforced, but I can't find another one any where on the internet. You're welcome to add part number suggestions. Anyway, I've got the blue/paper Fel-Pro intake gasket. I've seen guys apply grease to carb spacer gaskets and now I'm wondering if I should do the same? It seems to make since when I consider its going to get wet from the gasoline. When I think about gravity, it seems the bottom portion of the port will probably get wetter than the top portion. I guess grease would kind of water proof (or gasoline proof in this case) the gasket and keep a uniform seal. [/FONT]
[FONT="]So, any comments, or Suggestions ?[/FONT]
