Man, I did this 7 thousand times on my 98. It's the same. It's a combo of the two above posts. First, the trim butted agains the winsheild pulls straight up, no screws. That will reveal two screws to remove (10mm if memory serves me correctly). Pull the ash tray out and remove the third, and final screw which will be the same size. Finally, pull the whole shroud straight back towards the passenger area.
The defroster trim will come out easily, but the first time you pull the shroud, it will be difficult... so be patient and pull straight.
-X
PS-It might have only been 6,891 times, but you get the point.
