I have a 85 CJ-7 but have a 304 out of an earlier model Jeep. When I bought the Jeep a few years back the previous owner had told me that the motor came out of a 79 CJ-7. Recently though I had some charging problems and when I couldn't find the problem, the mechanic swapped out a new alternator. It appeared to fix the problem only to find out a few weeks later it hadn't.
I've taken off the alternator and since tested it and it passed. However I believe it may be the wrong alternator because I remember the previous alternator having 2 slots on the pully. This new one only has one.
The problem is that once I tightend down the alternator the jeep runs fine and fully charges. However after 100-150 miles its starts charging less and less until the point it finally quits charging. Once I remove belt and replace and retighten everything goes back to normal.
I think it may have the wrong alternator and that maybe the alignment of the belt is just slightly off or that the alternator is slowly loosing down the adjustor.
Any other ideas?
Also, how can I determine exactly what year model motor I have? Reason I ask this is because even though the previous owner said it was a 79 motor, when I changed out the distributor cap recently, a '79 distributor didn't match, what matched was off a '72.
My battery also tested good.
Any other ideas?
