cherokee axles in a yj?
The rear will need new spring perches and shock mounts welded on. The front, no.
The axleshaft will bolt right in, considering it's of similar year. There are slight differences like c-clip or non c-clip, and D35 or 8.25.
If you bent the axle shaft, make sure you didn't bend the axle housing as well....
It is bent at the very end of it, on the flange where the studs are, Thanks for the infor. I'am goging to go to the junk yard this weeken. For now I jsut put washers to make the tire striaght.
