Cj7 dui help
brewter2
Bought a DUI distributor for my cj7 304 but I'm confused how to wire it in ,can anyone help me? Explain
It's fairly straight forward and will vary slightly depending on what year we are talking about...... At the firewall bulkhead for the wiring harness, you'll find a large (8-10 gauge) red wire w/ a white tracer stripe that goes down towards the OEM igintion module (it's the small box mounted on the fender well below the steering column). You're going to cut it before the module, splice into it and run a new wire the "Batt" terminal of the DUI. Your DUI or any of the GM style HEI's are reffered to as "single wire" connections because you only have a single hot wire running to the cap. If for some reason you can't find the "Red" igintion control wire for the module (like if the harness has been hacked up or you have a "points" ignition), you can re-wire/splice into a circuit that is "key on/start". I have seen some guys use the starter relay (the "I" post) for this too- not a big fan of this route. But eitherway will be based on the existing distrubtor setup.
Personally, I like to remove all the factory DuraSpark (or points if its an older motor) components/wires during the install. But if you're not completely comfrontable with the install, you can leave them disconnected and in place until you're confident everything works.
FYI.... the other terminal on the cap is marked "Tach" which is for your tachometer. If you have the factory/OEM tach, you may have some difficultly setting it up. If that is the case, let me know and I'll help you with that too.
Keep me posted Bro...
John
What is the initial timing suppose to be?
What engine do you have?
I'd start with the factory timing (for the 258, 6-9 degrees) and work towards the best for your setup. Remember to open the plug gap to .40-.45.
Later, you can customize the timing curve but with the better units ( like your Davis) the pre-set curve on the vacuum can is normally sufficient for daily driving.
I think the factory timing was 8* on the 304, I would start there and try 10* as well. I think it will run better at 10*. Im going out in the garage in a minute and will check my manual on the timing.
Well, I went out to check and forgot I took it to a friends house. I will get it today
