Baseline 4x4
Rugged Ridge Cold Air Intakes, 91-95 YJ, 97-06 TJ, 07-10 JK, 91-01 XJ, 93-98 ZJ
Want more horsepower, better throttle response, and improved acceleration? A Rugged Ridge Air Intake System can boost your performance, while helping you keep extra cash in your wallet. Our polished aluminum mandrel bent intake tube replaces the restrictive factory air box to help improve fuel economy and performance. A black powder coated heat shield separates the filter from engine heat, dirt and debris, as cold air is drawn through a high-flow conical air filter. Unlike other reusable air filters, our dry panel design never needs oiling, which keeps your MAF from being damaged by excess oil! The simple bolt on installation gives you power you can feel, adding up to 10 HP and 12 ft lbs or torque, depending on application.
• Polished mandrel bent 6063 aluminum air intake tube.
• Simple no-drill installation bolts on using simple hand tools.
• Intakes kit includes black powder coated heat shield.
• 97-06 4.0L models include throttle body spacer.
• Improves fuel economy
• Adds HP and torque.
• Includes a high-flow conical dry panel filter that never needs oiling.
$162.95 a kit
17750.01 - Rugged Ridge Air Intake System, 97-06 Jeep TJ Wrangler 4.0L
17750.02 - Rugged Ridge Air Intake System, 97-02 TJ Wrangler 2.5L
17750.03 - Rugged Ridge Air Intake System, 03-06 TJ Wrangler 2.4L
17750.04 - Rugged Ridge Air Intake System, 91-95 Jeep YJ Wrangler 4.0L
17750.05 - Rugged Ridge Air Intake System, 91-95 Jeep YJ Wrangler 2.5L
17750.06 - Rugged Ridge Air Intake System, 07-10 JK Wrangler 3.8L V8
17750.20 - Rugged Ridge Air Intake System, 91-01 Jeep XJ Cherokee 4.0L and 93-98 ZJ Grand Cherokee 4.0L
17750.22 - Rugged Ridge Air Intake System, 93-98 ZJ Grand Cherokee 5.2L V8
17755.01 - Rugged Ridge Throttle Body Spacer, Jeep 91-06 4.0L and 91-02 2.5L
Free Shipping on all orders over $199!
Tony Feichter
Jeep Parts and Accessories
Baseline 4x4 Outfitters
1-866-554-5946 Toll Free!
260-636-7565
www.baseline4x4.com Jeep Parts and Accessories
TonyFeichter@baseline4x4.com
$162.95 a kit
Tony Feichter
260-636-7565
