Does anyone know if the Equus 3614 compression kit is compatible with my 97 GC V8, 5.2?
The kit comes with 6 different sizes to thread into the spark plug hole.....8mm, 10mm, 12mm, 14mm, 16mm, 18mm.
The gauge is only $25 bucks and looks pretty easy to use. I figure I should do this first before putting a new cat on and both o2 sensors....upstream and downstream, and new spark plugs and wires.
It has a lot of miles on it.....about 266,200 and I just have no power anymore since the check engine light when on (P0420 low bank 1) and it has gotten worse. I have been suspect of too much back pressure and it has never leaked oil before but now it is, fortunately not too bad.
I don't want to put anymore money into it if the engine is ready for rebuild.
