NuknFutsDemit
Hey everyone
Jeep grand Cherokee Laredo 4.0
219,000
Items replaced
PCM (bought online it was not programmed by the dealership)
Battery (refurbished)
Turn signal relay
I know some of these don’t relate to the problem at hand, just giving the info of all work done recently.
Issues
Gauges dead
Gas light, check engine, check gauges, no security lights are on.
Windows worked until today and now won’t go back up. They were working then I tried using the passenger side switch and now they won’t go up.
Attempts to fix
New PCM (after replacing PCM jeep runs fine)
Checked wires from radio to make sure none were bare and causing a short.
Checked plug on cluster
Found a ground just above the PCM to the right but not connected on the other end.
I gave as much info as i could if anymore questions please let me know.
219,000
Items replaced
Turn signal relay
Issues
Gauges dead
Attempts to fix
