TerryMason said:I don't have a locker but have been reading up on them (so pardon my ignorance). My understanding was that when running a lunchbox / selectable locker / anything but a spool - in the front, the locker will only come into play when in 4wd. In 2wd the front wheels will not receive power, and the locker will not engage.
[*]Open Differential = When a vehicle with an open differential meets a lack of traction, it directs power to the wheel with the least amount of resistance (tire in the air spins).
[*]Spool = the lack of a differential, 100% lock-up between both wheels of an axle all the time.
[*]On-Command Lockers = uses a switch to go from open differential to full locker
[*]Automatic Lockers = lock both wheels of an axle automatically when torque is applied so that both wheels are providing power. When torque is not being applied (clutch is press down) the differential is allowed to unlock.
- Automatic Lockers = lock both wheels of an axle automatically when torque is applied so that both wheels are providing power. When torque is not being applied (i.e. you press the clutch in) the differential is allowed to unlock.
What is the benefit of this?
Terry, my question is about the clutch. You said you would unlock when the clutch is used. Why would you want to depress the clutch when you are locked?
69jeepcj said:a lunch box locker works when engine throttle is applied, its automatic (hens the name, auto locker) There is no unlocking during throttle. You front tires turn at dif speeds during a turn so the locker has to account for that, and that is done when you let off of the throttle. When you let off, the locker unlocks, when gas is on, it is locked. It should never come unlocked under throttle. You have heard of the driving affects lunchbox lockers can have on the road, thats because of all the on and off throttle around town driving. The locker is locking and unlocking all the time and you get some jerks, noises, and the jeep may even swerve on the road. It doesnt sence wheel slipage and then lock, its gas on locked, gas off unlocked.
emjeep said:As expected there are as many opinions as there are lockers. One point of confusion for me is the term "lunchbox locker" does this refer to an automatic or is it a certinc type of selectable locker?
