Can i run a distributor from a 84 258 on a 78? I have the motor at T.D.C., but cannot get the rotor to line up with #1 cylinder no matter how much i try, even with aligning the slot in the oil pump I can't get it right. Do i need to use a different drive gear on the dist.? When i do get the dist. to seat, the rotor either points to the radiator or cylinder #2 but it just won't point to #1. Thanks for any help.
