I posted something in private message and that might have been the wrong place to do that so I will post it here instead. I drive a 2011 Jeep Liberty which I have had about 2 years. THe problem just started or at least I just noticed over the weekend. The key fob wont lock the doors. It makes all of the sounds and the light flash but it wont lock the doors. I tried locking the doors from inside using the buttons and that doesn't work either. When I open the door from the outside the alarm goes off, not all the time but sometimes or maybe its the panic button; they've both been going off. If I manually lock them, it works, but when I open the door on the drivers side all of them come unlock at the same time. I need help diagnosing the problem to see if I can correct it myself before seeking assistance elsewhere or taking it to the dealer. I replaced the car battery about a month ago, so I don't know if that would have anything to do with what is happening now. About 2 weeks ago I got into the Jeep and noticed the time was incorrect by several hours although I had done nothing to the battery as far as disconnecting it (the clock can be set and over time it is off by 10-15 minutes).
