I was told that a Ford E350 Van master cylinder will fit on my brake booster with a little trimming of the ears and drilling of the holes. Is this true?
I am trying to put together brakes for my axle swap (60/14bt). What proportioning valve should I use right below the master cylinder? Can I reuse the stock YJ one?
Will I need another adjustable proportioning valve for the rear axle?
