southtj
Active member
Check out the new Dodge Power Wagon with electric discos. :shock: I've never seen that before. You think they'll start adding that to the wrangler?
http://www.fourwheeler.com/roadtests/129_0410_powr/
Another trick new idea on the Power Wagon is the electronic disconnecting front antiroll bar. Dodge calls it the Smart Bar, and with the simple push of the dash-mounted switch, drivers can disconnect it. This electronically controlled device allows disengagement of the bar in both 4-High and 4-Low at speeds below 18 mph. Computers will re-engage the bar if vehicle speeds surpass 18 mph. In the event of loss of electronic control, the bar will return to its default setting and engage. With the bar disengaged, the Power Wagon posts an 11-inch increase up a 20-degree RTI ramp compared to the measurement with the antiroll bar engaged. Dodge numbers show it scoring a 655 on the 20-degree ramp.
