engine code came back on this time I got the freeze frame data
luis
Fuel system 1 closed loop Calculated load 22.3% Engine coolant temp 190 STFT bank 1 3.9% LTFT bank 1 32.0% Intake manifold pressure 7.9 in.h9 Engine rpm 2624 Speed 13mph. That's what the scanner good me when the code came back on p0171 system to lean bank 1
sounds like a vaccum leak somewhere if you already replaced the o2 sensor could be the pcv to I think it could set a code for that, but not sure on that
But with those numbers does everything look normal? I have no idea how to translate the freeze data
