Any tell tale lamps flashing?. Yes, the VTSS can inhibit an ignition if it's active. As for bypassing the sytem, IF its the EVS2 or EVS3 security system from Mopar, you can unplug the module from the ignition harness and completely remove it from the vehicle. IF it's the factory installed module, it's within the BCM(body control module).
