Front End Shimmy... Springfield
Chitreano
2004 Wrangler 4 cyl. 5 spd.
No lifts or lowered.
Non stock wheels
Non oversized tires.
At 52 mph I get a violent death wobble. I have rotated and balanced the tires, aligned the front end, had the entire front end inspected at a shop, changed the torsion shock in front, changed the shocks etc. etc. The death wobble returns.
Does anyone have a suggestion or a shop they recommend in the Springfield, Mo. area?
Thanks.
All too familiar with the "Death Shake" as I called it. But not without lift, tires, etc. You could try tightening the track bar components and see if that helps. After over a year of trying to fix it that is the one thing that finally helped.
Good luck!
Christian
