My dad is running one, the short arm version. It's a pretty cool set up. Flexes unbelievably well for a short arm kit. The only thing I don't like is that it tends to jack the vehicle when driving on the road, as in the rear end of the vehicle lifts. That is considering street manners. Offroad that means it plants the rear tires very well and gets a lot of force to the ground. The only install problem we had was the tail pipe routing. I also had to modify a bracket to work with the aftermarket dif cover he has. Oh, and it squeaks. It's kind of hard to fix this because it comes out of the johnny joint and they only have one lube port. It doesn't seem to get all the way around the joint. But that's to be expected with any suspension set up using johnny joints. I'd definitely recommend it for use on another rig that sees a decent amount of trail time for a street legal rig.
