1989JeepMatt
Hello all -
I have a 1989 Jeep Cherokee in-line6 4.0.
It has been overheating very erraticly and I have had the following repairs done to it.
New: Water pump. I have had the radiator flushed and pressure checked. It has been totally tuned up oil, plugs etc - the thermostat has also been changed. The fans are both working properly and the radiator though it came with the Jeep seems fine. I have has 3 mechanics also say that my head gasket is fine as is the overall health of the engine.
The vehicle: It has 182,000 miles but the engine is strong. The problem besides the overheating is it has many electrical problems. The most prominent problem is when I start it, it occassionally idles very very high and will not come down unless I shut it off and pop the hood, then wiggle the fuel injector bar wires on cylinder 5 and 6, the restart it. My rear defrost also will not shut off and I hear a clicking capacitor every few weeks under the dash which is weird - other electrical problems which I have are minor - flood lights no work etc.
A recent example of erratic overheating is this: I drove 100 miles non stop at 75+mph and the temp was a perfect 12:00 o'clock normal - hours later I overheated in traffic and also was unable to travel at 55mph without running a very high temp - starting off with a rested cool engine.
I have spent more than I can afford now and am reaching out to you all.
Thank you,
Matt in Mass.
Thank you,
Matt in Mass.
