granburymower
92 cherokee laredo 4.0 automatic transmission. Was running d
Then died. Replaced crankshaft position sensor ignition coil plug wires spark plugs distributor cap and rotor fuel filter fuel pump. Got fuel pressure. Got really good spark off coil very weak spark to plugs. Got 8.70 volts from ecu going into distributor. Turns over won't start. Any ideas. ?
