Holloween sale this weekend only XJ 4.5" RE6130M $1299.95 shipped
Allen's Offroad
Good day all! This is for this weekend only. You have to order by 3PM PST on Sunday November 3, 2013.
RE6130M XJ 4.5" Super-Flex system w/full leafs w/Mono Tube shocks 1299.95 shipped. Installation instructions.
Fits 1984 to 2001 Jeep XJ Cherokee
New PT-Meg Super-Ride bushings
Replacement front tuned coil springs
Replacement rear leaf springs
Adjustable upper and fixed lower front control arms
Serviceable Super-Flex spherical ball joints
Front adjustable trackbar
Swaybar disconnects, stainless steel brake lines, u-bolts and more
Easily upgradeable to Extreme-Duty Long Arm System
Rubicon Express Advantage Lifetime Warranty
Max Tire Size: 32" x 11.50
The Rubicon Express 4.5" Super-Flex suspension system for the XJ is designed as a complete suspension system replacement. The stock components of your Xj's suspension are upgraded with Super-Flex front control arms (allowing for proper caster adjustments), front coil and rear leaf spring and all the other components required to outfit your Cherokee with superb 4.5" suspension lift system.
Important Information
Vehicle will require alignment after kit is installed.
Rear pinion shims required if CV driveshaft used
Any tire wider than a 10.50 will need a BSM of 4-4.75"
Kit comes standard with D35 axle U-bolts.
For D44 rear axle use RE2445 U-bolts.
97-01Cherokees have smaller fender openings. Next size down tire size recommended.
Over 3.5-inches of lift on a full-time NP242 unit may cause unacceptable vibrations on the front driveshaft, when driven in ”part-time” or locked constant use 4WD.
All ride height increases are approximate and will vary due to vehicle specification (Engine size, factory options, trail equipment, etc).
For C8.25 or D44 U-bolts order kit with RE1225.
PM me your name, billing and shipping address, phone number, email address (for PDF receipt) to order. I will call you for CC info.
Thank you very much. I am truly grateful for your business. When replying please include all previous messages in PM (keeps a running conversation).
Namaste,
Allen
